Status
Not open for further replies.
1 - 1 of 1 Posts
Hey Gang,
I have been a Ht nut for awhile and a member of Home Theater Forum. Finally I get to have a dedicated HT in our new home. I am converting my upstairs loft. I hope you can help me with a difficult decision display decision. Currently I have an old Sony 27incher. I have the latest digital equipment and speakers. I would like to purchase a RPTV or even a projector. Here are a few my obstacles:
1) Budget. I would like to stay around $3000 give or take a bit.
2) The loft is upstairs and the staircase does a patter that looks like "\\" then it goes like "/" with a small flat area between the two levels. I don't know how I am going to get a RPTV up there. I was told that a Mitsubishi. Can separate into two pieces making it easier.
3) The room is large enough so that a 60" plus could fit no problem
I would appreciate any suggestions. Which models and what to expect to pay for them? Or should I invest in a front projector? I have also heard good things about the Pioneer SD-643HD5
Michael
[email protected]
1 - 1 of 1 Posts
Status
