Status
Not open for further replies.
1 - 10 of 10 Posts
Help me pick between the following projectors, thanks
Sharp 12000
BenQ 8700+
Optoma H77
Infocus 7205
The screen size will be 133" in a light controlled room.
....I believe the Sharp is generally considered to be in a class above the other three candidates.
The 133" screen is the issue here and one should always remember light output loss with bulb aging. That size screen would more likely require the brightness of the 7205. Be aware you could see pixels if your seating is less than 1.5 x distance from the screen.
An alternative could be the H77, given it has lens shift, and a High Power screen. Of course the pixel issue would still apply.
Dan
If you can go smaller screen, 12k.
If not, 7205.
Discussion Starter · #6 ·
What if I drop down to a 116" screen. My seating postion is about 17 feet away.
Banned
I would agree with a 133 inch screen, I would go with the Infocus, anything smaller I would go with the Sharp. If table mount the projector and get the highpower, then the Sharp might still be the way to go
Discussion Starter · #8 ·
Ok another look at my room again and the seating position is alittle over 15 feet. Should I down down to a 119" screen and is the 7205 still the best choice?
Just curious, why do you guys suggest Sharp over Optoma H77? I also am considering one of these. Also, is the Sharp 12k quiet enough to be directly overhead? Thanks
1 - 10 of 10 Posts
Status
