1 - 3 of 3 Posts
Hey, guys. I am looking to do a pretty thorough upgrade of my HTPC. Except for the Bach case, I'm basically starting over. Please take a look at the following list and tell me if you see anything terribly amiss. Keep in mind, I don't need the optical drive and I already have a LGA775 3GB processor and a Audigy 2 Platinum I'll use. Sorry for the length of the list, but I just did a copy of my newegg wishlist.
GIGABYTE GA-965GM-S2 LGA 775 Intel G965 Express Micro ATX Intel Motherboard - Retail
Model #: GA-965GM-S2
Item #: N82E16813128024
Return Policy: Limited Non-Refundable 30-Day Return Policy
In Stock
$109.99 $109.99
MSI NX7600GS-T2D256E GeForce 7600GS 256MB GDDR2 PCI Express x16 Video Card - Retail
Model #: NX7600GS-T2D256E
Item #: N82E16814127210
Return Policy: Standard Return Policy
In Stock
$114.99 $114.99
WINTEC AMPO 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 533 (PC2 4200) Dual Channel Kit Desktop Memory Model 3AMD2533-2G1K-R - Retail
Model #: 3AMD2533-2G1K-R
Item #: N82E16820161670
In Stock
$179.99 $179.99
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Model #: WD2500KS
Item #: N82E16822144701
In Stock
$79.99 -$5.00 Instant $149.98
Subtotal: $554.95
I'll be feeding a 720p plasma DVI-HDMI. I won't be doing anything that will require HDCP. Mainly using for streaming DIVx, etc and full size DVD ISOs. Since I can't use my XBOX360 add-on for upconverting, this is what I'll use for that. I'll be using XP for the time being and most likely will do a dual boot with Vista Home Prem later on down the road.
How do you plan to get the audio from the PC to the HT reciever? Do I see two digital obtical (TOS) on the front panel expansion thingie? Will you be using those or will you be using the copper digital out on the back of the card?
I ask for my own information.. I am planning something very similar.
Discussion Starter · #3 ·
I am using and will be using the sp/dif out from the Audigy card. Phono to COAX. All of my audio is just being passed through to let the receiver process it. I'm not siing the front panel box. I hate things coming off the front of a computer...
Especially when in my cabinet.
1 - 3 of 3 Posts
