Depends on your budget. This is the "reference plasma" in that range but the resolution is limited. The new Pioneer 43 and soon to be released NEC MP4 have 1024x768 resolution with comparable contrast ratios. These are in the $6500-$7000 range. Presumably Panny will follow suit with a higher resoution model as well.
Today this only matters with HD viewing and even at that you would likely have to sit quite close to see a difference.
