1 - 4 of 4 Posts
· Registered
I have a big library of ripped DVD image files (a complete, lossless image of the DVD), which i can play on Mac Mini using DVD Player. Although sometimes I found that my dedicated DVD machine plays better upscale, etc., in general I am happy with Mac's DVD Player. If you know a better software, I would love to hear from you.
Now, I am thinking of going in BluRay ripping. I have the following questions:
1. How to rip a complete lossless image of BluRay? Software, and hardware set up?
2. What's the end result of BluRay ripping? What's the software on Mac OS that can play a BluRay "disc image file?"
3. What are the requirement on CPU, memory, etc? (Do I need to get 2.66Ghz......)
UPDATES:
When I keep a copy of music, movies, etc., I always try to keep it completely lossless and original.
I have been ripping DVD in iso format, which is a complete and lossless copy, which I may revert back on to DVD medium any time I want to. For playback, Mac DVDplayer has been working fine. However, I find my good quality Harman/Kardon DVD Player 48 does a much better job rendering the image than Mac or PC does when it plays back a DVD. My DVD Play connects to TV via HDMI, my Mac and PC both connect to TV by VGA, which is also 100% digital. When I playback QuickTime downloaded movie trailer from Apple.com, it's perfectly HD!!!!
Now, I have the following questions:
1. Is there any DVD playback software can do a better job?
2. For Blu-ray, what's the best way of ripping and playback?
3. I understand that I can also rip Blu-Ray into ISO format. Any software on Mac can play back that just as good as those QuickTime trailers?
UPDATE 2:
last night, i ripped my first blu-ray into an ISO. .... not too bad... now, need players
UPDATE3:
On Windows, I can't find software that plays BD ISO. I have PowerDVD 9, which refuse to play BD ISO.
· Registered
Discussion Starter · #3 ·
Originally Posted by justinm0424 /forum/post/18229209
Total Media Theatre 3 plays blurays on Windows. I'm pretty sure VGA isn't digital which is causing your problem. Do you have HDMI or dvi-d output on your mac? I'm not a fan of mac and don't know much so excuse my ignorance
well, when connect a BD ROM to my pc, it's plays real BD disc output through VGA just fine.
· Registered
It might but is it playing 1080P? I was always under the assumption that VGA is analog connection like DVI-I whereas DVI-D and HDMI are digital connections. I believe that VGA can physically run 1080P but most videocards/Monitors don't support it.
I know at work I have 2-23" monitors and run dual display at 1440x900. One DVI-D, one VGA and the VGA can't handle over 60hertz and is struggling with the 1440x900 resolution. I see some picture shaking and lines sometimes but that also could be a video card problem as these are workstations.
1 - 4 of 4 Posts
