I'm using Runco 947, and have the same problem.
If you push the red CRT, it will move up & down slightly.
If you want perfect vertical alignment mechanically, you may need separate the red tube and reassemble.
I just align vertical line on the installation menu.
And I align horizontal line withe vertical shift on geometry menu grossly and fine adjustment on convergent menu.
