Hello all wise HTPCers out there - I am at my witt's end, pulling my hair out. I have built a nice simple HTPC to be a PVR mainly, running BeyondTV on a Hauupage 250 without problem...
However I have a huge problem running my video to my HDTV Component inputs. I am using:
Gigabyte - ATI 9600 SE Video Card with DVI-I - OUT
ATI DVI-Component HDTV Adapter
to a Samsung TXN3075WHF (30 inch 16:9) HDTV ...
I Cannot even get a picture at 640x480. I can see only a garbeled picture at windows' startup (light blue background) then a dark, off center image the right of the screen and half on the left with a thick verticle band down the middle. If I open a window or move the mouse quickly I completely loose sync.
I have tried timing adjustments with powerstrip, but I can't get anything, even the 640x480 to work.
I know the TV will accept a 1080i HDTV box signal, and also my XBox's 480p component signal without a glitch. and the DVI Out of the card works to a VGA Monitor (with the included DVI-VGA Adapter) - so anyoen know where my problem may lay... I have wasted countless hours on this with no success.
Thank you for your time
-Jeff
-Jeff
