Status
Not open for further replies.
1 - 5 of 5 Posts
Hi all.
I've been searching for about an hour using the search tool - using slow and slowest search, and I could not find an answer to this question:
I need Radeon Overlay Scoped Settings for PowerDVD XP!!!
All the posts point to overlay settings on TT - I don't have TT, so I know I can't use those.
At this point, I'll settle with ANY driver (I'm using Catalyst 2.4, but I don't care anymore) - every posts that asks for scoped settings suggests to look for Cliff Watson's Scoped Settings - but no one has actually pointed to an actual link/post about it.
Even after changing the search to WinDVD, Sonic, etc. etc. NOTHING came out - only scoped settings for TT.
I'm desperate - PLEASE... I need Radeon Overlay Scoped Settings for PowerDVD XP!!!!
Thanks a bunch in advance - I hope someone can help me with this.
Here you go. Set PowerDVD to the Original Setting and the Radeon overlay to the following.
Brightness = 0%
Contrast = 105%
Saturation = 100%
Hue = 0.0 Degree
Gamma = 1.2
This gives a peak white level at 712mV without clipping and black level at 0mV. Adjust the gamma to match your display device.
Discussion Starter · #5 ·
Cliff:
Thank you very much - I appreciate the help.
1 - 5 of 5 Posts
Status
