I received my ONKYO TXSR 603X and naturally ALL excited to start a NEW A/V Experience.........Spent ALL Day today wiring up different speakers etc.....and making what I believed to be the proper connections. Let me throw in here, I concur with others in reviews that I have read - this manual SUCKS!
My Components: A TOSHIBA 46" HDTV; A DISH 211 SAT Receiver; a TOSH DVD; and this NEW A/V Receiver. I decided to got for this model because of being able to do Component Switching [I may ROO that decision]..........I ran Component Cables from back of HDTV to OUT of A/V Receiver; another set out of DISH Receiver and into the Onkyo; and then one out of DVD and INTO The Receiver.
I also ran my Optical Digital OUT of the DISH Receiver and into the Onkyo - same goes for the DVD.
The MAJOR problem that has me baffled and writing here [I am BURNT OUT] is I can get NO SOUND - I am getting a picture on my TV off of the SAT - I have plugged and re-plugged in those Op/Dig. connectors and changed various settings till I'm blue in the face - to NO Avail.
A couple other things that I do not like so far and cannot understand: 1} With new/present connections I lost the ability to use the bulit in Audio System that is in the TV. 2} After the DISH Receiver and the A/V Receiver are on the same page, ie. Video 2 - I can no longer access the ON Screen Setup Menu for the Onkyo - - - because even with the SAT Receiver OFF, when I turn the TV on - that DISH Emblem scrolls around on the screen. 3} Changed TV Input from Video 2 to CABLE in order to get around inability to open up On Screen Setup again....BUT still I cannot access it? 4} Another BAD thing has happened using their Components in and out - - - almost everything being broadcast is in letter box or smallish and I can no longer change the formats using my DISH remote...with the A/V Receiver - what you SEE is what you get.
I remember - I think my old Sony A/V Receiver you had to choose like, PCM, or something like that and then the Receiver AUTO chose what the signal should be decoded as...............I was wondering IF there is something like that that I am missing????
I HOPE someone here can help me get this straightened out tomorrow - - - the way it is I sure wish I'd gone for a lower end Onkyo [503] and saved some money. I am probably going to have to re-connect my Component Cables to TV, DISH, and DVD the way they used to be before buying this sucker and HOPE that the SOUND will work again then.
THANKS for Any and ALL Help,
Michael
PS - - - Forgot to tell you - Speaker Setup was a SUCCESS and I still get Test Tones out of all of them.
Michael
