Hello. I was hoping to get a little help picking out an antenna from the pros. I live in 68803 with the following stats below. I was thinking about going with the CM 4221. Is this a good choice for my situation? Will I need a preamp with distances as follows? I only have 2 tvs hooked up max and will start with 1 for now. The only problem I don’t know how to address is the low vhf channel. What do you all suggest? Im open to any and all suggests on what kind of setup to get. Any other advice? There are so many choices, I just want to get the best bang for the buck and get a good solid setup. Thanks in advance for the help.
Yellow uhf KHNE 29 PBS 112° 18.2 29
*yellow uhf KHNE-DT 28.1 PBS 112° 8.1 28
*yellow uhf KGIN-DT 11.1 CBS 220° 29.8 32
Yellow uhf KTVG 17 FOX 213° 14.4 17
*yellowPTFeb uhf KHGI-DT 36.1 ABC 231° 29.4 36
Green vhf KGIN 11 CBS 220° 29.8 11
* greenPTFeb uhf KTVG-DT 19.1 FOX 213° 14.4 19
* green uhf KTVG-DT 17.1 FOX 213° 14.4 19
lt green vhf KHGI 13 ABC 230° 28.7 13
*redPTFeb vhf KGIN-DT 11.1 CBS 220° 29.8 11
*redPTFeb vhf KHAS-DT 5.1 NBC 172° 16.6 5
*red uhf KHGI-DT 13.1 ABC 231° 28.9 36
Blue vhf KHAS 5 NBC 172° 16.6 5
