Status
Not open for further replies.
1 - 16 of 16 Posts
Hi I am building my first home theater from seperates, always wanted to do so when i was a kid but never had the money, now that i do, most of it goes to my mortgage ;)
Heres what I have so far, I got a good deal on JBL E80s & JBL EC35 center, so I have them sitting in my living room. I will be getting an SVS PB10 sub pretty soon.
Of course all of the above is useless without a receiver eh? So after researching for 1.5 months & reading countless reviews I have shortlisted my choices to the Denon AVR-2105 & the Yamaha RX-V757 , both which I can get for $400 +/- a few $.
Both have nice reviews & I have never used any seperates apart from Marantz (which belonged to my dad & still does) so both of these guys will be new for me.
Any advise as to which one is prefered over what will be really helpful.
FYI I will be using it for 50% music & 50% movies, it will be connected to my PC also , so MP3s will be heard quite a bit.
Thanks in advance for any help :)
Discussion Starter · #3 ·
Originally Posted by CCarncross
Go out and use both and see which you prefer. BTW, seperates means seperate amps, pre-pro, tuner, not avr receivers....
You mean to buy both ? I just wanted to know what experiences you guys have had with both of these brands, more like which is good at what.
There is a similar thread here . I suggest you also do a search in this forum or the archive as this question has been asked several times.
Discussion Starter · #5 ·
Originally Posted by cmexec
There is a similar thread I suggest you also do a search in this forum or the archive as this question has been asked several times.
I see that you live in Brooklyn, I live in Queens, know any place where I can listen to both or each one at individual places ?
J&R retails both Denon and Yamaha. Last time I checked, they did have both models but it is not a an ideal listening area.
Discussion Starter · #7 ·
What would be an ideal listening area then ? If not JnR then where? I am not arguing but I am really asking since I have never bought anything before.
What I mean by ideal listening area is that J&R, unlike more dedicated audio outlets like Park Ave. Audio (park Ave. South) or Sound by Singer (nr Union Square), do not have a dedicated sound room where the systems are setup for demo and the room is acoustically treated. J&R just has a room where you can hear a receiver connected to a pair of speakers. There is no allowance for proper setup of the AVR level as would be the case in the other places I mentioned.
Sound by Singer carries Denon (although maybe the higher end stuff). You can check on the Yamaha web site for dealers in NY in case there is a place that has decent demo resources. Otherwise the other option is to demo in your own home.
Discussion Starter · #9 ·
Alright thanks for the information, I will pay them a visit may be after work today. Since I am more inclined towards Denon, will be enough to power the JBLs ? Its rated at 90wpc @ 8ohm & heres what JBL has to say about the E80s :
• Maximum Recommended Amplifier Power: 200 Watts
• Power Handling (Continuous/Peak): 100 Watts/400 Watts
• Impedance: 8 Ohms nominal
Does this mean that MINIMUM wpc requirement of the speaker is 100 watts? Thanks for any help you can provide !
No it does not mean that the minimum power required to drive the speaker is 100W but rather that the speaker handles continuous power at 100W but will peak at 400W. I would recommend trying the AVR with the speakers you are pairing it with to see if it sounds right for you.
I wouldn't use yamaha. I have an Yamaha HTR-5740 and it's most likely rated at 85wpc not 100 like some places. I heard the Yamaha are underpowered vs other receivers. They should nice though, but not as good as it could be. I have E80s as well as you can tell in my sig. I'm thinking of pairing it up with the Pioneer or the Onkyo tx-sr702 which I hear is a nice a/v receiver.
As I said before, as well as what others say, you should try to listen to the receiver and/or speakers you intend to pair together for yourself than decide. If however, you are fixated on the "all channels driven" thing, check out this and then this article
Discussion Starter · #13 ·
Thanks much cmexec for all your replies. I am not fixated on anything, just want to get something that makes me happy when I listen to it.
For now I think I will just demo at my place as I can tune & spend time listening as long as I want, I will start with the Denon since I like the features it provides.
I will let you know how it sounds with the JBL, I have no sub yet so this will be a true test of my components.
Discussion Starter · #14 ·
Ok so I got the receiver yesterday & as of now I only connected the front 2 speakers. I really like the clarity , soundstage. I put in my CD of Mike Oldfield & I really enjoyed listening to every song on the CD, even the ones I usually skip !
I obviously felt the lack of a sub but thats just my speakers. This is my first receiver & I think its worth every penny I paid for it.
However, I was able to take the volume full (the speakers are 8 months old so they are already broken in) & not feel the volume to be that loud or deafening. Is it supposed to be like that? Or is it something that I am missing ?
I did set the front speaker to "large".. Thanks for any help in advance :)
Discussion Starter · #16 ·
Originally Posted by Viwake
I think u have not mentioned finally which receiver did you pick up ?
I got the Denon but just a few days after that my friend was getting rid of his Marantz SR6200 for a lot less, which IMO sounds better than the Denon, atleast to me. So I returned the Denon & picked up the Marantz.
When I hooked my JBLs with the Marantz, the sound seemed to have more range, as it sounded better than the few days that I was used to with the Denon.
1 - 16 of 16 Posts
Status
