1 - 4 of 4 Posts
· Registered
Man, I'm confused.
Can someone give me a
little guidence...
There are too many to choose from.
I have a Comcast HD Cable box
Panny 800U TV
Sony Blue Ray player
And the Ht-S6100 with all 7 speakers connected
All connected with HDMI cables.
What are the best settings for
TV
Radio
BlueRay, DVD, CD
Thanks in advance
Jim
· Registered
There is no such thing as a "best" setting. It whatever sounds best to you.
I just use whatever signal is being sent to the receiver from the device.
Blu Ray movies will either send a TrueHD, Dolby Digital Plus or DTS-HD signal to your receiver depending on the movie. The receiver should automatically detect that signal.
DVD movies either send a Dolby Digital or DTS signal depending which one you select (or is available) in the audio options for the movie.
If you have a HD satellite box it will automatically send a Dolby Digital signal for the HD channels. For non HD channels its generally a two channel stereo mix and you can choose whatever sound mode sounds best to you. Dolby PLIIx movie or music is what I use.
Radio and CD are just two channel sources. You can apply All Channel Stereo or one of the other sound modes if you wish.
1 - 4 of 4 Posts
