Ok this is my last attempt to fix my htpc before I smash it to pieces and buy standalones. Basically I have had numerous issues all to do with blu ray playback at 24p and after trying all kinds of software and hardware solutions I recently changed my motherboard (due to another issue though) to the asus 8200 M3N78-VM. This board supposedly can playback 1080p HD no problems. Guess what? Not for me it can't. I have the 8200 using 256mb for the graphics memory and I have so far tried playing back a number of blu ray isos (all of which I know work perfectly) and what happens is that it plays fine for a few seconds and then the video seems to be in slow motion (dropping frames???) and this is how it continues. This is at 24hz and 23hz. 60hz seems fine but then I get judder as you'd expect. I have tried playback in PowerDVD9 & TMT3, cpu usage is around 10% (AMD 4850e) and this is all under vista with aero off, also using the latest nvidia driver. The hdd does seem to be taking a battering when playing the blu rays but indexing is off and so is defragmenting so I guess this is just because I'm playing from the hdd. So... does anyone have any ideas... at all...anything... if all you can suggest is smash it to pieces then please do because right now I might just do it...
Btw thanks in advance
