1 - 3 of 3 Posts
· Registered
Hi all,
I'm trying to find a 5.0 speaker system that will replace a set of relatively large home theater speakers in my parents living room. I was looking at both of these 5.0 systems (already have a sub) at newegg for about $199 and wanted to get your opinion on which you'd recommend:
- Polk RM10
- Energy Take Classic 5.0
I know the Polks are older/discontinued but it seems like the Polks have 2 woofers in the Center as opposed to just one in the Energy - does that mean that the voices will be clearer in the Polk than the Energy? Which would you recommend out of the two?
The room size is about 15 x 20. Thanks for your help -- looking forward to hearing back.
· Registered
Go with something bigger. Your room is too big for a micro system IMO. I would look for a system that goes a little deeper (60hz), compared to the 100hz of those systems.
My sister put a system from Polk in a room similar to your size room. To me it sounds terrible without much midrange/midbass. The sound was definitely lacking.
Find satellites with larger woofers (5 1/2"- 6 1/2"). Those dinky 3 1/2" won't do justice in a room that size.
1 - 3 of 3 Posts
