1 - 1 of 1 Posts
I cant figure out why 5.1 channel output doesnt work. I can get output from the two front speakers and when i do the test tone button on my remote it works with all 5 speakers and the sub, but when i either try to run the dvd/ld it only outputs in 2 channels and when i try to run dvd 5.1 it doesnt output anything at all. I set the optical in to receive on dvd/ld and I just cant figure it out. I know all the components are hooked up right and I think it should work from the optical output on the 360 but its not coming together. If anyone would be willing to help a novice I would really appreciate it. I want to start enjoying the pains of my labor as opposed to just laboring more thanks if you can help.
Luke
1 - 1 of 1 Posts
