1 - 2 of 2 Posts
I am hoping that one of the pros can give me a hand setting the 4308. I have never understood how cross overs work and what the appropriate settings should be.
I have a Elemental Designs Sub A5-350 http://www.edesignaudio.com/product_...roducts_id=618 and the specs are as follows;
Driver Size 15"
Driver Quantity 1
Driver Excursion 23mm
Total Driver Linear Displacement 3331.04cm³
Room Tuning 20Hz
Frequency Response (+/-3dB) 18-100Hz
Amplifier RMS Power 500W
Cabinet Type Vented
Shipping Weight 108 lbs
Internal Size 4.70ft³
External Size 6.37ft³
Width 19.00"
Height 25.00"
Depth 24.75"
Vent Size 2 x 4"
Amplifier Voltage 115
Included Crossover Yes
Crossover Frequencies 35-180Hz
Phase Switch Yes
Line Level Input Yes
RCA Level Input Yes
Level Control Yes
How should I set up the built in crossover on the sub and what setting should I put on my Denon?
Thanks you verry much in advanced for the help.
The control on the sub should be all the way up (180Hz) so that the Denon can control the crossover. On your 4308, you should run the full setup and Audyssey will set your crossover.
BTW, the crossover setting is determined by your main speakers, not the sub.
1 - 2 of 2 Posts
