1 - 3 of 3 Posts
Hello everyone.
We are performing a show right now using three acer P2570 DLP projectors. One of them has suddenly developed a distortion, where bright images show "ghosting" - as if they had a very fuzzy and ethereal offset shadow. This occurs even upon start up, so the Acer logo has a fuzzy shadow offset by a few inches. The other projectors do not show this fault, and they are all hooked up to the same power supply and cabled cleanly.
Any thoughts? We would dearly appreciate any help! We have two shows this weekend, and would really like to try to avoid renting another projector.
The fact that the splash screen logo is affected eliminates any sources. And certainly, this cannot be caused by the lamp. So, unless something is whacked in the settings, the projector has a fault that cannot be easily corrected. About the best thing you could try at this point is to do a reset back to factory settings. If that doesn't clear it up, then you're looking at replacing the projector.
1 - 3 of 3 Posts
