1 - 2 of 2 Posts
I own the following television:
Syntax Olevia 42" 542I LCD HDTV
I have Comcast Digital Cable with their Digital Cable remote control.
No matter how hard I've tried, I cannot locate the proper remote control code. As a result, I'm forced to keep two remote controls near me at all times when watching the television. If I could just get the correct code so that the power on/off and the volume up/down would work, I'd be thrilled.
Can ANYONE help???? I'd be eternally grateful.
Please reply back here or email me at: [email protected]
unless the remote accepts code 11610, you're out of luck sorry. The only remotes with a preset code for the current olevia are remotes released after the olevia were. Reason they're using a codeset NO other TV brand ever used before.
You can go to radio shack, the following models have preset code, 15-133, 15-134, or 15-135, code is TV 11610 also.
URC remotes like the R6 and WR7 have a code as well, it is TV 432.
1 - 2 of 2 Posts
