Status
Not open for further replies.
1 - 2 of 2 Posts
I just bought the VGA 15-Pin to 5 RCA (RGBHV http://www.digitalconnection.com/pro...les/vgabnc.htm so I can hook my htpc up to my big screen HD TV. But whenever i hook the vga from my video card to my bigscreen it says "signal not available". I am assuming that that is because the resolution is set to high on the computer, and that you have to some how adjust it to be the same as your tv's refresh rate, and resolution. Is this correct? And if so what is the right resolution, and how do you go about setting that?
Thanks in advanced, Jeff
1 - 2 of 2 Posts
Status
