1 - 8 of 8 Posts
I just got Optoma HD65 2nd hand. Everything is great except picture on the left side. It is shaking a little bit.
I don't know if there is some dusts got into my projector? What happen to my pj?
Please help any idea?
you know, i'm thinking its dust or a hair or something. i had something exactly like that on my benq, then i ended up taking it down and mounting it another room and it has been fine ever since.
Discussion Starter · #6 ·
Really, I might try to open it. Thanks for the info
Discussion Starter · #8 ·
Originally Posted by biztyke /forum/post/17049230
be careful, i have an hd65 as well and i have also opened it. it is pretty finickey, so take your time and don't force it.
omg, I got it fixed. I removed the lamp and blow toward the lens. You are the man. Thankssssssss
1 - 8 of 8 Posts
