I attached my tvfool analysis. I bought a new Winegard 7697 antenna to put in the attic. I also purchased a new Winegard AP-8700 pre-amp. I plan to hang it from the rafters in the attic and point it at +/- 125 degrees. My roof is plywood (7/16") and asphalt shingles.
Will this setup work? Now I'm thinking I may have bought too big of an antenna but I'm getting different results from TV Fool vs. antennaweb.net.
How about the attic setup. I will only have one 50" Plasma HDTV hooked up to it. The HDTV has a built in tuner.
If the antenna is too big, do you think I could get by with the Winegard 7694 or 96? It is much smaller. Thanks!!
