Hi there I was curious if anyone has any advice or experience with IR control with a Crestron Pro 2 controlling a PVR box. To recap my original problem I lost control of one of my 2 PVR’s, a Blu-ray player and volume control on a receiver. I had been troubleshooting the IR connections so much I think I may of damaged the original IR emitters I had coming out of serial outputs of Pro2. So after a bit of research someone recommended Xantech emitters. So I was able to buy some new ones online once they arrived I did the following below And here is the results;
1. First after I installed 3 new emitters I did get control back of volume control of receiver, control of 4K blu ray player however my TV box or PVR does go on now with some control but some strange things still happening
A). When go to change Tv channels with my ML 600 on PVR I get very slow response on button presses such as to change channels, or access TV guide. It is really painful to channel surf or flip between or search for new channels. PVR 2 which is hooked up to different serial output port is super fast at responding to commands. PVR 2 acting how it should respond. However PVR 1 does nothing at all after any button commands on ML 600.
B). I found out through trial and error that sometimes to unfreeze PVR control I find the only way I can do this is unplug my Pro 2 power and reboot it. I do gwin control back when do this for a while but PVR 1 commands not like PVR2 as far as responsiveness. And eventually all control goes away again.
C). Funny thing now is my basement TV won’t go on now when send command to turn on PVR. I physically have to press manual button on TV to turn on,but after toon still no actual control of channel surfing.
So curious on few things
1. Could it be where I am placing IR emitters on PVR? I notice in my experiences that this may effect it but should be common sense you place the emitter one would think? I have tried a few spots close to Eye on PVR, Hanging emitter in front of eye etc...
2. I do have black tape-over PVR 2 IR emitter should I do this on PVR 1. Should that make any difference?
3. Do you think it could be faulty PVR 1.? Faulty new IR emitter.? Faulty PRO 2. Location of IR emitter.
sorry for being long winded but any advice here or previous experiences where one PVR is fine and other is slow to respond.
And just curious why does unplugging PRO 2 help sometimes?
Thanks Again
Oil Country
Thanks Again
Oil Country
