1 - 5 of 5 Posts
· Registered
My LCD tv is 60HZ display that does a 3:2 pull down. Do I keep my player settings to 1080p 24FPS, or put them at 1080p 60?
I haven't noticed any judder, what do you guys think?
· Registered
Greetings
If you don't notice it anyway ... then why worry?
Do you worry about other things in life like this as well?
regards
· Registered
Discussion Starter · #3 ·
I am just trying to figure out if 1080p is best or 1080p 24fps is, even though my tv is 60hz and does a 3:2 pull down. A simple opinionated answer will do.
If It didnt bother me, I wouldn't ask.
· Registered
Greetings
Then the answer is yes ... do it.
but then again ... many TVs that say they take 24 fps just convert it to 30 fps anyway so it makes no difference whatsoever.
regards
1 - 5 of 5 Posts
