Status
Not open for further replies.
1 - 2 of 2 Posts
Hi All,
I am learning a ton from this forum but I could not find the answer to this probably dumb and simple question and was hoping for some help.
I am debating on an Over the Air STB (Samsung) and a Direct TV STB and wanted to know aside from HDTV will a DTV STB make every channel look better than my current DTV reciever. I know that I can not get HDTV with current DTV setup, but do not want to get new DTV setup if only 2 HDTV channels will be the difference when the over the air system I can get from a friend for less. Please tell me if the Set Top Box will make every channel better through upconverting or other method and if the Samsung would be compatible with my XBR450.
THANKS SO MUCH
JJ
Since you will be using a different connection (component) with the new STB, the picture will look a little better than your Receiver.
1 - 2 of 2 Posts
Status
