I have an annoying problem with my Seleco HT300, and I'm wide open to suggestions on this. This has done this ever since I purchased it brand new when they first shipped, in fact mine was one of the very first in the US.
First my DVD player is a Panasonic RP-91. MY Projector is a Seleco HT300 with the latest software installed.
My problem is that when I use the interlaced signal from the DVD player I see pretty bad vertical jaggies on any curved or round surface. The only way I can get them where they cannot be seen is to turn the sharpness and filter all the way down to zero, so then I lose all the detail.
When I use the progressive output then I get warped wavy vertical lines, meanig if you see a straight vertical line like text it is warped slightly and wavy.
I am using the RI2.
If I can get the thing to work properly with the interlaced output then the de-interlacing in the projector works much better than what is in the DVD player.
Thoughts on stuff to try. I have tried three different DVD players and they all do the same thing.
Anyone else seeing this??
Maybe that is just the way interlaced DVD output looks??
-- Cain
I am using the RI2.
-- Cain
