I have been driving myself crazy shopping for a 46-48" 1080 LED tv that will pair (over ARC?) with a soundbar for a new bedroom setup. I am unable to find two model numbers that will work the way that I would like.
The TV will be mounted on an opposite wall to the soundbar that will be installed into a bed headboard. I ran conduit between the two walls in order to run wires (HDMI?) across the room (20' total distance in conduit).
I would like to be able to power on the TV, and have only the soundbar speakers operate. I do not want to require the soundbar to get an IR signal from the remote, as it will not always have a clear line of sight. I would like the soundbar to power on with the TV and automatically power off with the TV as well. I also would like the TV remote volume to adjust the volume of the soundbar speakers.
If you know TV and soundbar model numbers that would work how I have described, I would love some help.
My budget for the project is around 800 for both the TV and soundbar.
Thanks much.
Thanks much.
