I hope someone here can help me. I know this might not be the best forum for this, but you guys here are the best at complicated audio setups.
My scenario is as follows:
I have 4 zones A - D. They are made up of overhead speakers connected via speaker wire.
I want to be able to do the following:
Via a microphone, I can toggle between which zones will be broadcast over. There will be two mic jacks, one in zone A and one in Zone B. So I want to sometimes broadcast only over:
1) Only Zone A
2) Zone B
3) Zone B and C
4) Zone D,B, and C (not really necessary)
5) Zone C
Next, I want a second input source (via line in or something like that) that will broadcast over zones B, C, D (but not zone A).
I also want it that I can have a different input (via a line in or something like that) that will broadcast over all four zones. (if this last one is not doable, then it is not the end of the world).
The three different input methods (Mic, line in, and line in) have to be connected at all times. It cant require swapping different plugs in the amp.
As far as using the microphone, I would need it that it can be toggled remotely (not by the amp itself, but somewhere else in the building - preferably by the mic jack and preferably analog - not some fancy digital panel) which zone to broadcast over. The jack by zone A can be set to only to broadcast over zone A. The only one that really needs toggles is the jack by zone B. It has to be able to broadcast over Zones B and C selectively. There also should preferably be a remote volume control by each of the two microphone jacks.
The only work that has been done so far is the wiring of the speakers and the mic jacks. All the wires come to one central closet.
What do I need?
What type of amp(s) can do this? The amp does not need to output theater quality sound as it wont really be used to output movies, mainly music and announcements.
Looking for input as I am a complete newbie with this.
Thank You
1) Only Zone A
2) Zone B
3) Zone B and C
5) Zone C
What do I need?
Thank You
