This is a copy from the same post in the high end Projectors. Someone there suggested that I post this here.
Please Help With Vertical lines showing with my new projector
Hello All.
First I am very new to all this
I just received an Eiki LC-X984 (A Sanyo PLC-XP18N clone) Projector
Basic Specs are below:
The problem I am having is: When hooked up to my new Progressive Scan DVD Player (Panasonic RP-82) through Component cables (Blue Jean Cables Brand), the picture has a lot of noticeable Vertical lines running up and down, the whole width of the screen? When I watch something in HD I cannot see these lines? I doubled checked to make sure the progressive scan is turned on the DVD Player and the projector accepts the signal as 480P. Anyone seen anything likes this or have any ideas? Any help would be great. The screen is 100inch diagonal
- Scott
Resolution: XGA (1024 x 768)
Display Device: 1.3" TFT Polysilicon x 3
Brightness: 2000 ANSI lumens
Uniformity: 90%
Data Signals: Compressed SXGA, XGA, SVGA, VGA, MAC, PC98
Video Signals: PAL/PAL-M/PAL-N/SECAM/NTSC/NTSC4.43
Video Resolution: HDTV; 1080i, 1035i, 720p, 575p, and 480p
Aspect Ratio(s): 4:3 (16:9 wide screen mode)
No. of Colors: 16.7 million
Contrast Ratio: 700:1
Lamp: 200W UHP
Lamp Life: not spec'd
Lens: Powered zoom and focus; 1:1.3 Zoom
F/1.8 - 2.1; f=1.9" - 2.5"
Image Size: 31 - 400 in. (diagonal)
Throw Distance: 4.6' to 48'
Keystone: Digital correction +/- 30 degrees
Proj. Method(s): not spec'd by mfg.
Input: 2 RGB (15 pin)
2 Audio Stereo Mini Jacks
1 Composite AV (RCA x 3)
1 S-Video
1 Component (RCA x3-Y, Cb/Cr,Pb/Pr)
1 mouse control port
1 mouse/RS-232 control port
Output: 1 RGB (15 pin)
1 External Speaker (mini jack)
1 Audio (mini jack)
H-Sync Range: 15-100 kHz
V-Sync Range: 50-100 Hz
Built-in Audio: Two-piece, 3-watt Stereo
Audible Noise: not spec'd
Weight: 15.2 lbs.
Dimensions: 10.7 in. (W) x 16.2 in. (D) x 5.7 in. (H)
Hello All.
- Scott
Uniformity: 90%
Lamp: 200W UHP
1 S-Video
1 Audio (mini jack)
Weight: 15.2 lbs.
