Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
Hi-
Everytime I try to use Zoom Player with FFDSHOW, I get huge lag and sometimes total unresponsiveness in any given DVD's menu. I have disabled all of FFDSHOW's settings and just had it run in Zoom Player's "additional filters," and it still causes this. Playback during the movie is fine. At first I thought it was because I had too many options selected, but like I said, with nothing selected, it still staggers.
When I disable FFDSHOW in the "additional filters" box, zoomplayer runs fine.
My system isn't the fastest, but it's no slouch:
AMD mobile 2400+ (running @ 2.2ghz)
512mb Corsair Ram
Abit NF7-S v.2
Ati Radeon 9600xt
I figure if I can run Far Cry without a hitch, I should be able to get the DVD stuff up and running with some pretty good filtering. If anyone can point me in a worthwhile direction I would be most happy. I want to buy ZoomPlayer, but only if I can get FFDSHOW to work.
thanks
geoff
· Registered
Discussion Starter · #3 ·
Indeed I am, which I forgot to mention. Thanks. I haven't tried it yet, though I did get my hands on a copy of PowerDVD (turns out it came with my DVDROM) and used the filters from that and zoom player works perfectly and looks pretty fantastic too. Between this and WinDVD (hopefully it will work), I may not have to buy the Sonic filters at all.
thanks,
geoff
1 - 3 of 3 Posts
Status
