1 - 4 of 4 Posts
ordered the logitech g51, have not opened it. i wanted to connect it to a tv. my room is just 10x12 Feet. i don't want anything overpowering. should i send this system back? max budget is around $200. just afraid won't get full surround sound after reading reviews. Thank you all.
You are correct. You will not get DD nor DTS 5.1 from this system. Nor will it come anywhere near overpowering your room, in fact it will probably be vastly underpowered. This system is made to hook into a computer's sound card, not a TV. For the money you can purchase a system actually designed for home theater.
1 - 4 of 4 Posts
