Status
Not open for further replies.
1 - 5 of 5 Posts
Hi,
Just putting together my HTPC and want to go for a good sound card to output DD/DTS sound thru SPDIF to an external amp. Right now I got a old SB LIVE platinum and was looking to replace it. Thinking of going in for a AUDIGY 2. Can anybody recommend any other good sound cards?
bye
I personally use the Soundblaster Audigy 2 ZS. The soundblaster cards dont appear to have a lot of support here but I use the cards in 3 different htpc's and have never had a problem. I use both the spdif/rca option as well as the audigy external drive option that has optical. Both work flawlessly for me and the output is phenomenal.
I had rough going with the built in SoundMAX Digital Audio card on my motherboard. After poking around this and other forums, I got a lot of recommendations for the M-Audio Revolution 7.1. I got one, and have been very happy with it indeed.
This forum needs an FAQ
Should I buy a soundblaster for my HTPC?
Answer: It is good for gaming and DVDs. Not a good choice for listening to Audio CDs since it resamples all 44.1Khz data to 48Khz and in the process reduces the fidelity of the signal.
Cheers
Thomas
Mitsubishi HC7800, Onkyo TX-NR686 , Sony Blu-Ray, Spectrum TV, 104" screen, 7.1 sp w/ 400W Sub
I have an Audigy 2 and have been very disappointed in it. The reason is that when I let the card do the Dolby Digital/DTS (AC-3) decoding of DVDs the video judders and tears when the camera pans. This with a 2.4Ghz P4 w/ 533Mhz FSB, Albatron PX845PEV Pro MoBo, 512MB of PC2700 RAM check at an average of 20% CPU utilization when playing DVD. To get rid of the problem, I now pass SPDIF through as you want to do. When you do this, I don't believe the sound card is doing anything to the signal. If you have a mother board with on board sound and SPDIF out (even if it's just pins on the board as my Albatron has). I would save my $ and try the onboard chip first.
BTW, Creative seems known for below average support. When I brought my problem to their attention they responded suggesting that I was decoding AC-3 twice. Well, the onboard sound is turned off in BIOS and since PowerDVD4 I have only passes on SPDIF, the only other place to decode it is in the Audigy2.:mad:
1 - 5 of 5 Posts
Status
