RTV4040
Please help me. I have a 120 gig maxtor master and a 80 gig maxtor slave that were previously in my rtv system. I noticed skipping so i decided to low level format and start fresh.
Ok, I low level formatted and certified each of my two drives. After 20 hours it was finally done. I load RTVPatch 2.1.3 and set the target drive and the second drive. I clicked on retore target drive and it asked for a rtv file, so i browsed to the 500 mb file i saved when it asked me to backup before i decided to format. anyways, after I loaded the backup, i clicked on make dual drive system and i am getting an error saying invalid cluster size on partition 2, and i see in the rtvpatch window replay disk 2 or 2 on the second drive and not a replay disk onthe first drive.
The first drive was the 120 gig the second drive was the 80 gig.
heres a copy of the logs. please help. i sure hope i do not have to reformat!!!
RTVPatch version 2.1.3 (beta), built on Feb 16 2002, 14:33:31
%s (%s) : Used WinXP drive size detection
\\\\.\\PhysicalDrive0 (ST34313A) : Detected size = 8452080 sectors
\\\\.\\PhysicalDrive1 (Maxtor 4G120J6) : Detected size = 240121728 sectors
\\\\.\\PhysicalDrive2 (Maxtor 4D080H4) : Detected size = 156312576 sectors
Copy from source 'C:\\Documents and Settings\\TV Room\\My Doucments\
tv.rtv' at offset 0
Copy to destination '\\\\.\\PhysicalDrive2' at offset 0
Copying 1034242 blocks (505MB)
*** Resetting MPEG partition
Enabling RTV4000 byteswapping functions
Partition 1 size is 1024000 (0xfa000) blocks.
Partition 2 starts at sector 1024002 (0xfa002)
Partition 2 cluster size is 262144 bytes.
Partition 2 root directory located in block 3.
CRC is 0x2f3f
XOR byte is 0x4e
*** MPEG partition reset is complete
*** Restore complete
***** ADDING SECOND DRIVE *****
***** Clearing partition table on drive \\\\.\\PhysicalDrive2...
***** Writing volume sequence block on drive \\\\.\\PhysicalDrive1...
***** Writing volume sequence block on drive \\\\.\\PhysicalDrive2...
***** PATCHING DISK *****
Disk 1 of 2 is \\\\.\\PhysicalDrive1 (240121728 sectors)
Disk 2 of 2 is \\\\.\\PhysicalDrive2 (156312576 sectors)
***** Patching partition block...
Original partition table values:
Partition 1, type 0x00, start: 0, length: 0
Partition 2, type 0x00, start: 0, length: 0
Partition 3, type 0x00, start: 0, length: 0
Partition 4, type 0x00, start: 0, length: 0
Clearing 3rd and 4th partition settings
Partition 2 will be 396434300 (0x17a11b7c) blocks.
Partition 2 cluster size is 0 bytes.
*** ERROR: Invalid cluster size for partition 2
Target disk is \\\\.\\PhysicalDrive2 (156312576 sectors)
Partition 2 will be 156312574 (0x95123fe) blocks.
***** Clearing volume sequence block...
Partition 2 cluster size is 1048576 bytes.
***** Reading signature and FAT blocks...
***** Patching signature and FAT blocks...
Number of clusters is 0x12a24.
*** ERROR: Suspicious FAT block, not patching CRC checksum...
XOR byte is 0xee
Partition 1 size is 0 (0x0) blocks.
Partition 2 starts at sector 2 (0x2)
Partition 2 root directory located in block -1571541801.
*** ERROR: Root directory cluster number is not valid
***** PATCH COMPLETE *****
Patch complete
Partition 2, type 0x4d, start: 2, length: 396434300
here i restarted the program and tried again
0) ST34313A - (4 GB) - May be PC Disk
1) Maxtor 4G120J6 - (122 GB) - NOT a ReplayTV Disk
2) Maxtor 4D080H4 - (80 GB) - ReplayTV Disk 2 of 2
Source: 1) Maxtor 4G120J6 - ( 122GB ) - NOT a ReplayTV Disk
Target: 2) Maxtor 4D080H4 - ( 80GB ) - ReplayTV Disk 2 of 2
XOR byte is 0xee
Patch complete
tv.rtv' at offset 0
CRC is 0x2f3f
XOR byte is 0x4e
XOR byte is 0xee
Patch complete
XOR byte is 0xee
Patch complete
