Status
Not open for further replies.
1 - 2 of 2 Posts
My Plus! Digital Media Edition Dancers are not able to detect sound (do not start automatically and even when started manually do not dance to music) even after clicking Detect Sound Now in Dancer Options dialog box. I have already checked the Audio Tab in the Sounds and Audio Devices and both the Sound Playback and Sound Recording entries are set to M-Audio.
Additionally I am trying to decide between HS10 and LT260 to be used with my HTPC. I have a dual head (one head is a touch screen running myHTPC) with Radeon 9000 (running both heads) and MyHD cards so the output from my HTPC is going to be VGA (not available on HS10). I prefer a wide projector but if I go to a wide resolution for the projector the 4:3 touch screen running myHTPC will look funky.
Thanks in advance
Banned
Sorry, but this is a restriction in the way the audio detection works in Plus. I believe it has to do with the audio loopback method used to capture the system sounds.
Amir
Microsoft
1 - 2 of 2 Posts
Status
