Status
Not open for further replies.
1 - 1 of 1 Posts
Help!
Can someone please tell me what the distance is from the front holes (where the "feet" are mounted) to the front of the lens?
I have to mount my bracket for the PLV-60 this weekend. I have the unit on order but can't wait anymore as the drywall is coming next week and I'm mounting the unit inside a soffit.
The bracket screws into the holes where the "feet" are mounted and the unit is mounted inverted. In order to know how far back from the front of the soffit I should install the mount, I need to determine the distance from the front of the lens to the "feet".
Thanks in advance.
Larry
1 - 1 of 1 Posts
Status
