Status
Not open for further replies.
1 - 3 of 3 Posts
I have read through a number of posts but couldn't find the answer . . .
I have had a Sanyo PLV-Z2 (firmware 108) paired with a Samsung HD931 for about a year connected with a long set of wires.
From the Sammy out the wires are 5m to 3m to ex-tend-it booster to 5m to pj (42 feet total. The booster is hooked up correctly.
I have been watching 720p out of the Sammy (so i don't think this is an HDCP issue) but have always wanted the 1080i I paid for.
However, the 1080i setting only produces static with a momentary blue screen, then a still image (grainy and torn) then back to static. I thought this was a weak signal so I hooked up the player direct with the only the 3m cable with the same results.
2 questions:
1) is this just a cable length issue?
2)does the samsung have low output
anyone using this combination of hardware or suggest player that works with this length of wire?
Also, is the 1080i worth the trouble. I use a 92 in diag. screen
Discussion Starter · #2 ·
Just got the last Denon 1910 the store near me had for $190.
The 1080i mode works. Its not as visually stunning as I hoped but at least it works. I will never buy a samsung again.
1 - 3 of 3 Posts
Status
