1 - 2 of 2 Posts
Hi
I Recently purchased a Pn50b550 and love it. I was doing some research before i bought this one and was looking at the 560. This was not available at the store in my area so the 550 was what i went with. I was going over the specs and they looked identical other then the 560 having cinema mode. I read on some forums that they are identical hardware just different firmware. Is it possible to flash the 560s firmware onto the 550 to enable it to have cinema smooth.. If this is possible has any one done this before
thanks
From everything I have read, I dont believe this is possible. One difference between the 550 and the 560 is that the 560 (and above) have the crystal full hd chip/engine which I believe handles or at least is associated with the cinema smooth capability. So do to the hardware difference, I doubt purely a different firmware would allow cinema smooth.
1 - 2 of 2 Posts
