1 - 2 of 2 Posts
I'm in the market for a new set of speakers (excluding sub - I already own one).
I have been eying the Polk Audio RM95 5-Channel Home Theater System and was wondering if anyone had an opinion on these, or recommendations for something better for the money?
I am using a Denon 1517 w/ a BIC F12 subwoofer (I love this!!)...
10 ft ceilings with open living room / kitchen... viewing area of about 15x25...
Thanks in advance for any and all replies!!
I would not recommend that system for two reasons;
First, they are not big enough for the room.
Second, those speakers have a configuration that makes them difficult to place and avoid inappropriate reflections off of walls etc. Big problem. I'll bet that is why they are dumping them so cheap.
I suggest that you get a pair of Wharfedale Diamond 10.1 speakers and add the matching Diamond 10CC speaker. Those are MUCH better-sounding speakers.
Apparently you have some speakers now and can use a couple of them for rear/satellite speakers.
1 - 2 of 2 Posts
