1 - 1 of 1 Posts
There are two different in wall subs that polk makes. Trying to stick with one brand for speakers to keep the sound the same. Curious if anyone has any experience with the two:
Csw100: is the under floor type
Csw155: is the in wall enclosed type
The frequency response is roughly the same on both. I plan on buying two, but it will be two of the same type ( two in walls or two under floor).
They will be powered with one of the swa500's that polk recommends. Curious if that's enough power for the both of them as well....
If you do have experience with either one, is one better than the other? Prefer accurate over loud.... Just curious if anyone that has one is partial to them or not...
1 - 1 of 1 Posts
