I need some help here. Just here recently I have been coming home from work and when I start up a movie or my xbox360 my right channel isnt working. I take out the banana plugs and put them back in. Check the connections on the reciever/speaker both. Keep toying with it and now it comes back on. Its been doing this for about a month or so? Some days it does it and some it doesnt. The right speaker also crackles and pops a bit when its first on but once you have had it on for a couple of minutes, it goes away.
Is my right channel going out or do I maybe have a connection problem? I was thinking of getting out another set of my banana plugs and connecting those and see what happens from there. I do have the warranty on them but I dont wanna mess with it right now if its just a connection at the speaker.
I did try my left channel over on my right side and its fine so I am sure its not the receiver.
Any ideas? Should I take the back plate off and look inside for anything loose or desoldered?
