1 - 4 of 4 Posts
I have Denon X3600H and I would like to run 5.1.4 with another set of speakers in Zone 2 (Polk S55) - I am thinking of using an external amp Amp100VS to power Zone 2 as the AVR can only power 9 channels.
Would AMP100VS (they are rated at 50 watts for 8 Ohm) be sufficient to drive Polk S55 (90 db sensitivity, 20-200 Watts, 8 Ohm) - from a very limited understanding I have, I think it should be sufficient but this is my first set up and I am very new to this so any help is welcome.
Should be fine. At 90 watts sensitivity, you will probably only be using a fraction of one watt at any particular moment.
Discussion Starter · #4 ·
Thanks @RayGuy and @eljaycanuck - I am looking at a couple of used AudioSource, will snag one at a good deal.
1 - 4 of 4 Posts
