I would like to get some feedback to see if people with a CH 2.35 setup without masking wish they had a masking systems for 16:9 and 4:3 video content.
AVSForum Tech Talk Podcast with Scott Wilkinson Click here for details.
Enter to be our Home Theater of the Month Click here for details.
Originally Posted by acksnay /forum/post/0
So count me in the Nope column. Say now ... where is that poll?
Originally Posted by snooktarpon /forum/post/0
I screwed up on setting this up as an official poll. Sorry.
Originally Posted by BOSS10L /forum/post/0
Can I ask a dumb question? If you have a CIH screen, a scaler and an anamorphic lens, then what would the need be for a masking system? Any non 2.35 content would be scaled so by the video processor, and then correctly sized by the lens, no?![]()
Masking for CH 2.35 systems mask the pillar box (black bars on both sides of the image) as a result of watching 16:9 or 4:3 video content on a 2.35:1 screen.
So even having a scaler (a la DVDO) and an anamorpic lens will still result in pillar box bars?
Originally Posted by mustang5o /forum/post/0
Also (correct me if I am wrong), in an ideal CIH setup you would move the lens out of the way or get a lens with a pass thru mode so that 16x9 material was displayed natively and therefore the projector would not be putting out black pillar box bars. Having side masking in this case makes more sense so that you don't see the unused sides of the screen. Which could be reflecting light as well.
The point to Constant Image Height is that you always use the full vertical rez of the projector for all Aspect RatiosActually, I think the goal should be to use full vertical rez, horizontal rez, and available brightness from the projector. I don't think its good to throw something away just because we're more sensitvie to something else.
If you use a scaler to compress the image horizontally, masking will likely be more important than it is if you move the lens or use a pass thru mode.
I use a lens with pass thru mode and still use side masking to reduce light from relections within the room. To me, its fairly easy to do and very worth while - plus, you can completely close the curtains when the screen isn't in use.
