Hi,
Trying to figure out which one of these is the best for me. Aside from the physical options (SATA drive, BD drive, SD card slot, LCD display, etc.) they appear to be the same spec wise.
The Smart H1 (I don't really care about drive options so I'm looking at the cheapest (at least on duneplayer.com) Dune, the H1) supports Real3D while the C200 supports MKV3D...not sure what that means/what the diff is.
The Smart H1 supports 24p output while the C200 doesn't?
Am I missing any other differences here? How does firmware stability and update frequency compare between the two companies? From what I can gather on this forum, the Dune products have a better track record regarding f/w stability but PCH has finally caught up and has a product that is just as solid?
>glc.
>glc.
