This may not be the perfect forum for this question but it's a bit unusual so I'll just give it a shot.
I travel for work - a lot. I'm also an avid console gamer. I've been trying to put together a portable gaming rig to recreate as closely as possible the console gaming experience while travelling on a plane.
There are 3 major problems here:
1) Power source. I need something that can run a PS2 and a display for 3+ hours. I have found several portable battery solutions so far, the best of which looks to be the Brunton Solo Personal Power Plant . But I'd like to know if anyone knows of any other products out there that might be smaller/lighter.
2) Display - I need some way to view the video output from the console. It has to be light and portable. I travel with a laptop but I haven't figured out a way to pipe the video through to my laptop screen. I've also considered head-mounted displays but haven't been able to find a good one. A portable LCD monitor would work but I haven't found one yet. Any ideas?
3) Size - All of this gear has to fit in an airline carry-on size case. 14"x9"x22" is the maximum, but I'd loke to get it a little smaller than that.
So there it is... quite a project. I'm trying to keep the cost under $1000. Any help or insight would be greatly appreciated. Also, before someone says "why don't you just load games on your laptop?", let me go ahead and answer that one: not enough battery life, and I don't like most PC games.
ST
ST
