Hi, i'm curious if anyone knows if it's possible to have satellite AND cable hooked up to the ReplayTV with listings for each or is the guide strictly 1 input? I'd like to be able to switch between inputs and record shows that I can't get with cable on the satellite, but the catch is i'd like them scheduled so that it turns the channel using the serial cable. Cable would use the IR blaster. I'm using the 5040 model.
Thanks for taking the time.
