Hi all,
I've been playing around with subwoofer build ideas for when I have the cash to build one, and was wondering if the current build I'm looking at would suit my needs.
I'm looking to make a subwoofer that is relatively inexpensive ($500 or so), reasonably good looking, and as good sounding as my budget will allow. I'm looking at using the 15" Dayton Audio Ultimax woofer, the 3 cu. ft. Dayton knock down cabinet, and a 500w Bash amp.
http://www.parts-express.com/dayton-audio-15-ultimax-subwoofer-and-cabinet-package--300-7097
http://www.parts-express.com/bash-500s-digital-subwoofer-plate-amplifier-500w-rms--300-752
My current setup is an Emotiva XDA-2, XPA-200, and a pair of Thiel CS 1.6 speakers. I was wondering if this subwoofer would be quick and detailed enough to keep up with/integrate well with the Thiels. I am looking for a subwoofer that has very good transient response and a punchy sound primarily for music with the occasional video game and movie. I'd like it to go as deep as possible, but I understand that at this price I won't be touching the lower limits of my hearing range. I don't need high volume.
I'm also wondering whether how it would perform against other non-DIY subwoofers in a similar price range such as the SVS PB-1000 and the Rythmik LV12R.
I'm also open to other woofers and amps, compatibility with a knock down cabinet I can purchase is a huge plus as I do not have the tools to make a cabinet myself.
I was looking to have the amp be an external amp in a custom wooden enclosure similar to Bottlehead amps. I was planning on this because I wouldn't have to cut a hole for it, and I think it would look more interesting. I slapped together a quick render of what I was thinking about to give you guys a better idea of what I'm talking about. Are there any issues with a setup like this, or would it work well enough?
Also, a somewhat unrelated subwoofer question. When hooking up a subwoofer via RCA (the XDA-2 does not have subwoofer out, so I would be using the RCA out) should I plug it into one channel only, or both? I've heard I should only plug in one channel, but I fear that I may miss some bass information on the other channel.
Hi all,
