1 - 1 of 1 Posts
I got a recommendation from a fellow member here a while ago to buy a behringer ep2000 amp to run a sub box with 2 subs in it. I want to drive it at 8 ohms bridged. I plan on sending the signal to the amp from the sub preamp outs from
a Denon 3312 receiver.
Here are a few questions. The amps have 2 different input ports, which should i use. I know I can buy the rca to whatever adaptors, but I am a bit worried that the output signal will not be the correct voltage for the amp input, Ive seen a few people with these concerns and can't find the answer.
second, why a ep2000 and not an inuke nu3000 which seems to be made specifically to power a sub.
The help is greatly appreciated.
1 - 1 of 1 Posts
