1 - 7 of 7 Posts
Just wondering - in a rack/enclosed space, what are best practices for keeping power cable routing clean and safe? Something tells me bundling them up tight could be a potential fire hazard.
I run power cords vertically on one side of the rack, and signal/LV cables on the other. Most of my components have the power cable on the right side, when viewing from the back, so I run them on the right. Use 2 lacer bars for the component which has the power cable on the wrong side.
Originally Posted by Neurorad  /t/1470056/power-cable-management/0_50#post_23248139
That makes sense, I'm about to wire up my rack and that sounds like it will work well.
I have an MA ERK rack with rear door. How do I go about getting and attaching rear rails?
doublepost
The neatest way is to get a vertical power strip mounted to rear rack rails and plug each component into that via short power cables.
Discussion Starter · #7 ·
Thanks for the advice. In general its difficult to get correct length power cables, since the equipment I use is a mix of 3 prong female, 2 prong female, coaxial DC with a brick, and coaxial DC with a wall wart. In some cases the cable is not even removable from the equipment.
Currently I am running power cables down one side, but again they are all bundled together and I'm a little concerned about that.
I'm kicking around the idea of the vertical power strip. One problem is I have the Middle Atlantic ASR rack (the pull out and rotate rack), its not exactly the same as a usual rack, I might have difficulty finding something that will fit it properly. The only one I found was this one:
http://www.cableorganizer.com/home-theater-system/slim-power-strips.htm
1 - 7 of 7 Posts
