1 - 5 of 5 Posts
from time to time i get this wave from the bottom of my tv and usually goes to the middle and stops. i was wondering if this a power issue. i have a new 60 inch plasma, xbox360, ps3, a pioneer elite receiver , sat tv hooked vup....just wondering what this is. all my components are hooked up to a monter surge protector..would a power center make a difference? thnx!
A power center may make a difference. Try it and make sure that you check with the store's return policy. I have the Monster 3600 mkII powercenter and an Onkyo 906 AVR. I have heard that with some problems the powercenters do work.
Maybe the Monster(TM) surge protector is causing the prob.
what AV Doogie said .. a rolling horizontal band that only happens sometimes is usually interference from something ..
1 - 5 of 5 Posts
