1 - 14 of 14 Posts
I just want to know what is the best solution to connecting my receiver (Pioneer SC 25), amp (B&K AV 5000 series II), SVS PB12-Plus/2 powered sub, and all the rest of the A/V gear (60"PlasmaTV/PS3/WII/AppleTV/Blueray Payer/Sat Box) to an electrical outlet? The wall outlet is a 15 amp-110 standard outlet. I currently have APC 1500 back-up ups, a Monster HTS 1000 Power strip line conditioner as well as a "heavy duty looking" Tripp-Lite surge protector. My question is how to best use these products.
Would it matter to use 2 separate wall outlets(same circuit) or is one enough if done correctly. Would it be worthwhile investing in a stand alone power conditioner?
I would put everything on the APC but the amp and use the Tripp-Lite for that and use the HTS in another room or TV.
Discussion Starter · #3 ·
Would it be advisable to plug the Monster into the APC and run as you described? Also when plugging into the APC would it be recommended to put the Sub and Receiver into the Back-up part or not?
Originally Posted by moodyda  /t/1494631/power-conditioner-recommendations#post_23829902
It has always been stated never plug a surge protector into another surge protector and I think it has to do with the filters not so much the surge protectors themselves.
Discussion Starter · #5 ·
Would a Panamax or Monster full size power conditioner provide provide superior protection and leveling voltage?
Originally Posted by moodyda  /t/1494631/power-conditioner-recommendations#post_23830414
Ilike both APC and Panamax full size AV units your choice but yes that would work but if your amps draw a lot of current you may want to look at FURMAN 20 amp series.
Discussion Starter · #7 ·
The Furman stuff looks pretty expensive. What will work with my gear or a couple of hundred,,,,, that's all
Furman & Panamax are a merged company so products do share some capabilities.
I replaced all but 1 still functioning Monster unit with Panamax and have no regrets. IMHO, Panamax are better built products. I've had problems with 2 out of 3 Monster power centers, one lost its trigger relays and one lost functionality to 3 outlets (1 outlet had nothing plugged into it) due to their chip-controlled disconnect circuit. I will not buy another Monster Cable power-surge product again, period. My original 20A Panamax 4400 bought about 9-10 yrs ago is still working NP.
You don't have to pay MSRP for Panamax if you shop wisely
I've had good luck buying from One Call (an authorized dealer) but I know there are others with great service who are willing to come a bit off list - call on the phone
I've looked into a lot of MOV surge protection based power center products and in the several hundred to
I wouldn't buy a Panamax. I have a M1500 UPS that's needs service. Panamax no longer does out of warranty work and I can't find any one that will work on my Panamax either.
Discussion Starter · #10 ·
I have recently read that no power conditioner is the way to go. Explained further that all newer electronics are built to deal with this and that adding a power conditioner could actually degrade the harmonics from your system. So I think that I will forego this unnecessary investment.
Originally Posted by moodyda  /t/1494631/power-conditioner-recommendations#post_23836157
I would not forgo surge protection and a true power conditioner (the ones I have seen) do to the size of the coil would not fit in any of these boxes they have filters but do not actually perform as a true conditioner IMO.
I own a panmax and I currently have it hooked up to my brand new Samsung PN60F8500. Are you telling me I should unplug my TV from my panmax? Damn!
Would you happen to have the link for this article referring to.
Sent from my LG-LS970 using Tapatalk 2
Originally Posted by ss9001  /t/1494631/power-conditioner-recommendations#post_23834525
I agree on the Belkin units. My entire HT system, including two powered subs, has been run off a single Belkin PF-60 for a number of years. With the system going at full tilt, according to the LED display, the current draw does not go beyond 6 amps. I've compared this display with system current draw and mains voltage measurements from my Fluke meter, and it is pretty accurate. The PF-60 has a high current outlet bank for amps that has only parallel filtration, so that current draw is not restricted. I've heard no downside to using the unit.
Discussion Starter · #14 ·
Originally Posted by bigjoexxl  /t/1494631/power-conditioner-recommendations#post_23838083
This video has interesting information regarding power conditioners, http://www.youtube.com/watch?v=LyI85XOKzZ4
1 - 14 of 14 Posts
