Power Conditioners and DoubleThink
857 Views 7 Replies 6 Participants Last post by  Chu Gai
Nowadays, just about everything you plug your equipment into is touted as a Power Conditioner so long as it does something to the AC. Sometimes it's even touted as a Power Conditioner if it does nothing to your AC, but that's another story! In any event, without too much effort, you'll find people who've gotten tangible benefits such as a reduction of hum or a cleaned up picture on their TV. Also, without too much effort you'll hear things like my soundstage opened up, there was more air, microdynamics were improved, and the usual suspects.
However, what happens when the explanations given by various manufacturers contradict each other? Well then you have what George Orwell in 1984 called DoubleThink. Doublethink means the power of holding two contradictory beliefs in one's mind simultaneously, and accepting both of them. Usually, manufacturers are pretty careful not to tread on other's claims. That might mean they'd have to get into a pissing war. So usually, you have this implicit understanding that manufacturer A won't say B's product or claims is bull$hit because then B would say the same thing.
Anyways, let's look at two products from two different manufacturers: PSAudio's P1000 Power Plant and ExactPower's UltraPure AC Line Purifier. PSAudio states,
In fact, what you get out of the wall is noisy power, full of unwanted harmonics and varying in voltage from as low as 105 to as high as 130 depending on where you live and the time of day.
How does this affect your audio video system? Noise and harmonics will increase the noise floor of an audio system and cause the setup to have a bright and hard glare associated with each musical note. With video, the noise can reduce three dimensionality of the picture and lower apparent color saturation.
OK, fine, let's go with that. They're saying that if your system has noise and harmonics that'll affect the resulting sound in an adverse way. Therefore, a product that reduces this would have a positive impact on a user's experience. Conversely, a product that either did nothing or exascerbated noise and harmonics should be detectable as having a negative impact. Now ExactPower's UltraPure AC Line Purifier, apart from being a balanced unit is also supposed to clean up the AC. So, we would expect that any measurements of this product with respect to the AC should show a rather uniform reduction of harmonics and noise. No? Well, this product was recently reviewed by Secrets at http://www.hometheaterhifi.com/volum...06-part-1.html I found of particular interest the following graph,
http://www.hometheaterhifi.com/volum...fier-graph.gif
Now, if we're to take PSAudio's comments and the design intent of the ExactPower to heart, how does one explain the rather substantial worsening of the AC when this product is used? Wouldn't it not be reasonable to assume that using the ExactPower unit should result in negative audible consequences? Or should we just assume that any benefit the product has comes from the fact that it's balanced and would serve to attenuate hums as a result of connecting two products that have chassis leakage? Or is it just a matter of DoubleThink where we can accept one explanation as valid and rationalize the performance of the other which is diametrically opposite. Certainly someone is selling bull$****, no? Bad boys, bad boys. Whatcha gonna do when they come for you?
See less See more
Status
Not open for further replies.
1 - 8 of 8 Posts
The only power conditioning that really works (improves sound and video) is the Shunyata Hydra and accompanying power cords.
Other power conditioning products usually inhibit current flow or do not improve the AC that reaches the components. The end result is worse than no conditioning at all. The only benefit usually derived, is surge protection.
Shunyata is the real deal and you can take their claims and equipment reviews to the bank.
Where's the smiley?
No really, where's the smiley?
Originally Posted by Targus
Where's the smiley?
Funny :D
Originally Posted by Ethan Winer
Targus,
Hi Chu,
Thanks for the link.
So is your reference to "Doublethink" in regard to Mr. Johnson's surprising conclusion that, despite his graph, he doesn't seem to have a problem with the additional noise in this "affordable" $2,000 conditioner?
ExactPower is a notable company in the area of AC line conditioners. Their newest product, the UltraPure, appears to perform as advertised. It gives you low-pass filtration and balanced power, at an affordable price.
I have to admit I'm confused by his review. If he feels that distortion in the audible frequencies greater than 60 hz is not a problem, he should have explained why that is. Otherwise what was the basis of his favorable review?
Larry
See less See more
I don't know. I think really what it points out when you take common sense into the mix, then you have to realize that whatever benefit the ExactPower confers upon a user are because it provides balanced power. That benefit will only be realized if he's got equipment that's got such chassis leakage that it results in an audible hum when connected. The rest of what the product does, well, that's like buying a car because it's got a cigarette lighter in the trunk. Useful, if you're locked in and need a smoke. But is that really the reason you ought to be buying the car?
1 - 8 of 8 Posts
Status
